How to check SIP gateway configuration for FAX
raffi.shaik
Hi all,
Can you advise i have configured SIP gateway for fax on router 2811 .
Need to check whether the conf correct or not.
Please find running conf.
Thanks.
Rafi
raffi.shaik
Hi All,
i m getting below error can any one know the solution.
Please help.
dldsipgw(config-controller)#pri-group timeslots 1-16
% Not enough DSP resources available to configure pri-group on controller E1 0/0/0
% The remaining dsp resources are enough for 0 time slots.
% For current codec complexity, 1 extra 16 channel dsp(s) are required to create this voice port.
Rafi
