How to configure an analog port on the VG to not have to dial a 9 first
tenmill08
Can someone provide the proceedure on how to configure an Analog port on a Voice Gateway to not have to dial 9 first?
6 Replies 6
Charles Hill
Is this a call manager express or call manager?
MGCP gateway or SCCP gateway?
Hi Cehill,
This is CUCM 8.6 Service Update 5 we are using MGCP.
Thx for any insight
Still working on it.
Created a translation pattern to call 9.
-> Create a new partition "9accessPT
-> Create a new CSS "9accessCSS"
-> Add the 9accessPT to 9accessCSS
-> Create a translation pattern, with a blank translation translation pattern and a called party transform mask "the number you want dialed"  **********If i enter 9and a number, it automatically calls out, if i put only a 9 in the called party transform mask it does not.********
Urgent priority is checked.
-> Add the calling search space to the phone.
I'm thinking its not hitting a valid route pattern, since the 9 has already been dialed.
Any ideas?
If you get it working, let me know.
Hi Cehill,
It seems like the issue is that the customer don't want to dial the 9 to get outside line ,they basically  want to beable to dial a number with out dialing 9+1 and the 10 digits, I think this would warrant a new CSS,Route Pattern,Partitions  etc.. correct?,
Got it working!
-> Created a new route pattern with @ and added it to the 9accessPt
-> Create a translation pattern, with a blank translation translation pattern and a called party transform mask 9
If anyone sees a problem with this config, please chime in, but all is testing ok.
I was attempting to use the existing route patterns by automatically dialing 9, but it wasn't working without the new @ route pattern.
Charles Hill
-> Create a new Partition
-> Create a new CSS
-> Add the the new partition to the new CSS
-> Create a new route pattern @ and assign it to the new partition
-> Add the new CSS to the analog phone.
 Hope this helps.
