How to Configure Calling Phone To Show Called DN When Forwarding to Hunt Pilot.
tanan.ead1
Hi All,
     I have problem when Calls Forwarding to Hunt Pilot , I want to make "my phone" to show Destination DN not Hunt Pilot DN , How Can I Fix This ?
On Destination Phone , Its Show my phone DN not Hunt Pilot normally. (Display Hunt Pilot Name or DN for Hunt Group Calls When Alerting Required Field = "False") Problem with Calling Phone Only.
CUCM 10.5
Please advice me.
Thanks.
You change the service parameter 'Alway display original dialed number ' to true. But this is global parameter which will impact all calls
No , I want to see the  "Line Group Member DN."  not Original Number or Hunt Pilot Number too.
Thanks for Reply.
If you want to see the Line Group Member DN then ​please make sure that the “Display Hunt Pilot Name or DN for Hunt Group Calls” under service parameter is set to false and do not put any value on "calling transformation mask" on the Hunt pilot config page and test a call. This should work hopefully.
-Venkatesh.
Sure, i set to fault and not use calling transform mask.
         This Solution you reply is use to Fix with "Called Phone Display" not  "Calling Phone Display".
Thanks for Reply..
