How to Configure Cisco 7921G with Asterisk
Amardeep Kumar
HI
I have to configure Cisco 7921G with Asterisk ( Trixbox) server. Can some help how to do it ?..
Do this phone support SIP Protocol. OR any other way to setup it with Asterisk.. ?
Amardeep
Jaime Valencia
It's an SCCP only device, don't see how you can get it to work with Asterisk.
Protocol  support
• Skinny Client Control Protocol (SCCP)
• Cisco Unified Communications Manager Versions  4.1, 4.2, 4.3, 5.0, 5.1, 6.0, 6.1, 7.0, and later
• Cisco Unified Communications Manager Express  Version 4.1 and later
• Cisco Unified Survivable Remote Site Telephony  (SRST) Version 4.1 and later
• Cisco Compatible Extensions Version 4.0
• XML
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6788/phones/ps379/product_data_sheet0900aecd805e315d.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
HI
So is there any Chance to configure these phone with Asterisk with SCCP Protocol.
Amardeep
SCCP is a Cisco proprietary protocol.
java
java
There are some veriosn of sccp channel in asterisk by which you can integrate SCCP endpoints directly with Asterisk  you can try  with the steps mentioned in the below  link
http://www.voip-info.org/wiki/view/SCCP-HOWTO2
