How to configure MGCP Fractional T1 on CUCM 7.x
1ashlee2794
Hi All,
Are there any special steps to configure a fractional T1 or E1 for a MGCP Gateway
on the CUCM Gateway config page?
Let`s say where you only want to use/configure channels 1-12?
Any assistance will be greatly appreciated...
Many thanks...
KingofKingz
Jaime Valencia
You need to use the service parameter "Change B-Channel Maintenance Status" to busy out the unused channels from CCM .
Even if this is possible you need to be aware before doing so that THIS IS NOT SUPPORTED BY CISCO.
If you want a supported method then you need to switch to H323
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Payal Bhaduri
I am sending you a link that will help you to busy out ISDN B channels.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008076f8d2.shtml
