12-20-2011 11:11 PM - edited 03-16-2019 08:38 AM
I have IP-PBX Asterisk connected to Cisco AS5350 using SIP protocol. Users of Asterisk may call through the AS5350 but they can not send fax using t38 in conjunction with G729 but fax can pass when i change codec to the g711.
I have noticed that when i use g711 and try to send fax the codec of session is changing to the t38 and fax is passing. But when i use g729 and try to send fax the changing of session codec to t38 not occur, fax does not pass and session terminating occur.
At the Asterisk side i use DigiumFax application.
Here is configs of cisco and asterisk:
voice class codec 701
codec preference 1 g711alaw
codec preference 2 g729r8
codec preference 3 g723r63
codec preference 4 g723r53
codec preference 5 g726r16
codec preference 6 g726r24
codec preference 7 g723ar63
codec preference 8 g723ar53
codec preference 9 g711ulaw
codec preference 10 g729br8
codec preference 11 clear-channel
dial-peer voice 59536311 pots
destination-pattern 050564....
direct-inward-dial
port 1/0:D
forward-digits 7
dial-peer voice 595363111 voip
incoming called-number 050564....
voice-class codec 701
session protocol sipv2
dtmf-relay rtp-nte
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
no vad
[general]
context=default
bindport=5060
bindaddr=0.0.0.0
t38pt_udptl=yes
allow=alaw
allow=g729
dtmfmode=rfc2833
language=en
canreinvite=yes
t1min=1000
rtcashefriends=yes
defaultexpiry=60
[TO-5350]
type=friend
host=192.168.11.2
fromdomain=192.168.11.2
context=default
canreinvite=yes
t38pt_udptl=yes
disallow=all
allow=g729
allow=alaw
dtmfmode=rfc2833
nat=no
Help me to fix this problem.
12-21-2011 12:08 AM
Hi.
g729 is not a suitable codec for t38 with modern fax machines. This because g729 can scale up to 7200 bps and higher fax speed requires an higher bandwidth then g729 can offer.
That's probably why your faxes ar passing while using g711.
Carlo
12-22-2011 01:40 PM
Try adding this to the voip dial peers at both ends of the IP link:
fax-relay ecm disable
fax rate 7200
fax nsf 000000
This will tell the 5350 to limit the fax rate to 7200 baud, and also overwrite any NSF codes that are not supported. Where I work, the ECM tends to mess things up for us at this data rate, so we also disable it as well.
This will force the fax machines to train at the slower rate, and they will take longer to complete, but this will use less bandwidth to do it.
Wes
12-22-2011 01:42 PM
Try adding this to your voip dial peer:
fax rate 7200
fax nsf 000000
Wes
