How to connect ISDN phone to cisco router?
aherraez77
Hello:
I am trying to connect a ISDN Phone to a bri port in a VIC2-2BRI-NT/TE, but the calls doesn´t work in both direcctions. The VIC is installed in a MGCP GW.
Here is the configuration that I am using:
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
isdn skipsend-idverify
line-power
end
voice-port 0/2/0
cptone ES
bearer-cap Speech
show isdn status bri 0/2/0
Global ISDN Switchtype = primary-net5
ISDN BRI0/2/0 interface
******* Network side configuration *******
dsl 8, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 64, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 8 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
When I call the number of the phone from a DN of the call manager I have the following output from the debug isdn q921 and q931:
Sep 7 10:55:39.455: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num +XXXXXXXXX
Sep 7 10:55:39.455: ISDN BR0/2/0 Q931: Sending SETUP callref = 0x0013 callID = 0x8030 switch = basic-net3 interface = Network
Sep 7 10:55:39.455: ISDN BR0/2/0 Q921: Net TX -> UI sapi=0 tei=127
Sep 7 10:55:39.455: ISDN BR0/2/0 Q931: SETUP pd = 8 callref = 0x13
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Display i = 'XXXXXXXXXXX'
Calling Party Number i = 0x0081, '+XXXXXXXXXXXXX'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, 'XXXXXXXXXXXX'
Sep 7 10:55:39.519: ISDN BR0/2/0 Q921: Net RX <- SABMEp sapi=0 tei=64
Sep 7 10:55:39.519: ISDN BR0/2/0 Q921: S4_SABME: Sending UA
Sep 7 10:55:39.519: ISDN BR0/2/0 Q921: Net TX -> UAf sapi=0 tei=64
Sep 7 10:55:39.539: ISDN BR0/2/0 Q921: Net RX <- INFO sapi=0 tei=64, ns=0 nr=0
Sep 7 10:55:39.539: ISDN BR0/2/0 Q931: RELEASE_COMP pd = 8 callref = 0x93
Cause i = 0x80D8 - Incompatible destination
Sep 7 10:55:39.539: ISDN BR0/2/0 Q921: Net TX -> RR sapi=0 tei=64 nr=1
Sep 7 10:55:49.539: ISDN BR0/2/0 Q921: Net TX -> RRp sapi=0 tei=64 nr=1
Sep 7 10:55:49.547: ISDN BR0/2/0 Q921: Net RX <- RRp sapi=0 tei=64 nr=0
Sep 7 10:55:49.547: ISDN BR0/2/0 Q921: Net TX -> RRf sapi=0 tei=64 nr=1
Sep 7 10:55:49.555: ISDN BR0/2/0 Q921: Net RX <- RRf sapi=0 tei=64 nr=0
Sep 7 10:55:59.555: ISDN BR0/2/0 Q921: Net TX -> RRp sapi=0 tei=64 nr=1
Sep 7 10:55:59.567: ISDN BR0/2/0 Q921: Net RX <- RRp sapi=0 tei=64 nr=0
Sep 7 10:55:59.567: ISDN BR0/2/0 Q921: Net TX -> RRf sapi=0 tei=64 nr=1
Sep 7 10:55:59.575: ISDN BR0/2/0 Q921: Net RX <- RRf sapi=0 tei=64 nr=0undeg
I don´t know why is not working since I am using a typical configuration for this.
What I am doing wrong?
Best Regards.
Manish Gogna
The Layer 2 shows TEI_ASSIGNED status , that's the reason calls are not working. The Layer 2 status of PRI/BRI should be MULTIPLE_FRAMES_ESTABLISHED. You need to share the running config to check for any issues with that.
Manish
