How to connect two Routers via BRI ISDN?
Daniel Flieth
i want to connect my two Cisco Routers via the BRI Interface in both routers.
I thought i could configure the first router as network side and the second as User Side
Network Side:
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
isdn skipsend-idverify
line-power
User Side:
interface BRI0/1/0
no ip address
isdn point-to-point-setup
isdn tei-negotiation first-call
But this will not work.
Do you have any idea? I also tried is with static tei.
Best Regards
Daniel
5 Replies 5
acampbell
Daniel,
Yes this does work
You need to use a BRI cross cable
3 -------------5
4 --------------6
5 --------------3
6 --------------4
See link http://www.cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a008010ef6c.shtml
Also on both interfaces add
isdn static-tei 0
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hello Alex,
Thank you for your answer. Today i´ve got the following q921 output
Jan  9 12:36:39.073: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Jan  9 12:36:40.073: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Jan  9 12:36:41.073: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Jan  9 12:36:42.073: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Jan  9 12:36:42.073: ISDN BR0/1/0 Q921: User TX -> IDVER ri=0 ai=0
Jan  9 12:36:44.073: ISDN BR0/1/0 Q921: User TX -> IDVER ri=0 ai=0
Jan  9 12:36:46.073: ISDN BR0/1/0 Q921: L2_EstablishDataLink: sending SABME
Jan  9 12:36:46.073: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Jan  9 12:36:47.073: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Jan  9 12:36:48.073: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Jan  9 12:36:49.073: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Jan  9 12:36:50.073: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Jan  9 12:36:50.073: ISDN BR0/1/0 Q921: User TX -> IDVER ri=0 ai=0do sh isdn st
Jan  9 12:36:52.073: ISDN BR0/1/0 Q921: L2_EstablishDataLink: sending SABME
Jan  9 12:36:52.073: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Jan  9 12:36:53.073: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0atus
Global ISDN Switchtype = basic-net3
ISDN BRI0/1/0 interface
        dsl 2, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 2 CCBs = 0
    The Free Channel Mask:  0x80000003
ISDN BRI0/1/1 interface
        dsl 3, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        Layer 2 NOT Activated
    Layer 3 Status:
    Active dsl 3 CCBs = 0
    Total Allocated ISDN CCBs = 0
Maybe it was because i only configured isdn point-to-point-setup on the user side?
Daniel,
Look at the output you have shown:-
Layer 1 Status:
DEACTIVATED
The physical level is not connected
Check cable etc
Notice that the debug only has TX frames no sign of any RX.
Alex.
Hello Alex,
no BRI0/1/0 is active.
I also wonder why only TX Frames and no RX Frames.
Dont really know why.
Daniel,
The NETWORK end will alway try to stay up whether a cable
is plugged in or not and will continue to send out SABME frames until it
receives a UA frame
You may need line power at the USER end.
On the the NETWORK end try adding.
int bri 0/1/0
line-power
Please also recheck that the cable is a ISDN/BRI cross as I have
detailed above.
Alex.
