How to convert CP-8861-3PCC-K9= Phone to a CUCM phone
Gia Reynolds
I recently received a CP-8861-3PCC-K9= Phone from a vendor. I need to convert the phone to be used on CUCM not a 3rd party system. Can this still be done?
5 Replies 5
Jaime Valencia
Yes, instructions and requirements can be found here:
https://upgrade.cisco.com/
java
if this helps, please rate
The solution that was sent will not work. I have a 3rd party phone CP-8861-3PCC-K9= that needs to register to a Call Manager.
Did you open the link and looked at the options on the left???
Did you read the documentation???
java
Yes, on both questions. To be clear the phone options are different for 3rd party phone.
OK, then I don't know what else you're looking for, the MPP->Enterprise option is what does what you want.
java
