How to delete MGCP efficiently
eigrpy
Level 4
Level 4
Hi The interface for MGCP was configured wrong in gateway router. I need to delete all MGCP in the router and cucm. Do you think there is a good way to delete it? Thank you
5 Replies 5
Jaime Valencia
Choose MGCP GW and click delete on CUCM, use no form of the MGCP relevant commands on IOS.
java
if this helps, please rate
Thanks for your reply. The main thing is that there are a lot commands relevant with MGCP in the router. Just no ccm-manager and ccm-manager server cannot delete all relevant commands. Do I need to delete all other mgcp commands which produced automatically when I created the gateway in the router?
Nadeem Ahmed
You can simply go ahead delete the GW which you have added as MGCP on CUCM and on Gateway share the show run so that i can tell which all command needs to be removed from there.
Br,
Nadeem Ahmed
PS: Please rate all useful post.
Br, Nadeem Please rate all useful post.
Thank you. Please see the file in attachment
run this command on GW
no ccm-manager switchback immediate
no ccm-manager redundant-host x.x.x.2
no ccm-manager mgcp
no ccm-manager fax protocol cisco
no cm-manager music-on-hold
no ccm-manager config server x.x.x.1
no mgcp
no mgcp call-agent x.x.x.1 2427 service-type mgcp version 0.1
no mgcp dtmf-relay voip codec all mode out-of-band
no mgcp rtp unreachable timeout 1000 action notify
no mgcp modem passthrough voip mode nse
no mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
no mgcp sdp simple
no mgcp fax t38 inhibit
no mgcp rtp payload-type g726r16 static
no mgcp profile default
also i see you have mgcp with PRI you need to removed this one as well if you not running this GW as MGCP.
controller T1 0/1/0
 cablelength long 0db
 pri-group timeslots 1-24 service mgcp
interface Serial0/1/0:23
 no ip address
 encapsulation hdlc
 isdn switch-type primary-ni
 isdn incoming-voice voice
 isdn bind-l3 ccm-manager
 isdn bchan-number-order ascending
 no cdp enable
for this you need to shut the controller and do "no pri-group timeslots 1-24 service mgcp".
shut
no isdn bind-l3 ccm-manager
and configure it again and last do "no shut".
Br,
Nadeem Ahmed
