how to delete voicemail messages
commonman
Hi all,
One user is asking how to delete all messages at a time in his voicemail box , we are using unity 5
Please help me on this
thanks
Vipul Jindal
i think best way is to delete the voicemail box and re create it.
nothing else i can think off!!
thanks,
Vipul JIndal
please rate if it helps!!
boris.kudr
Hi mate,
You can enable IMAP for that use and use email client to delete messages.
Also, you could use Cisco Web Inbox page.
Boris
