How to design fax transmission through ATA 187
Fikri FIRAT
Level 5
Level 5
Hi all,
We wish to implement ATA 187 devices to take care of fax transmission. In the CUCM 8.6.2 , I configured the device as follows :
Web Access  : Enabled
Auto Barge : Enabled
CDP : Enabled
Fax Mode : T.38 Fax Relay
Fax Error Correction Mode Override : Off
Maximum Fax Rate : 14400bps
Impedance : 600 ohms complex
Input Audio Level : NoDbPadding
Output Audip Level : NoDbPadding
Caller Connect Polarity : User forward polarity
Caller Disconnect Polarity : User forward polarity
Callee Connect Polarity : User forward polarity
Callee Disconnect Polarity : User forward polarity
Caller ID : Bellcore FSK
Call Sequence : Bellcore FSK
Reorder Delay : 0
Mute progress Tone : Disabled
The Line is OK, makes phone calls, but does not send / receive fax.
I'm new to the ATA device, the bottom line is how to design fax transmission using ATA 187 devices over T.38 and CUCM v8.6.2
Thanks in advance,
Hi Fikri,
In case of SIP, you can apply the following config on your VG:
! Fax configuration for Inbound / Outbound VoIP dial-peer
dial-peer voice voip
  fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through
  fax-relay ecm disable
  fax nsf 000000
  fax-relay sg3-to-g3
HTH.
Harmit.
10 Replies 10
Harmit Singh
Hi Fikri,
Can you provide the exact call flow please? What protocol are you using on your ingress / egress voice gateway? Is the ATA at a remote location? Are you running the latest ATA firmware? Can you attach the running config of the ingress/egress voice gateway?
Harmit.
Hi Harmit,
ATA is in a lab environment, so currently is not at a remote location only the fax device is connected to the ATA, and it should send/receive fax through T.38, currently there are no configs on the voice gateway regarding fax transmission, the design will be from scratch, ATA load id : APP187.9-2-1-0
Harmit Singh
Hi Fikri,
Just to add to my previous message, here is a typical call flow where ATA 187 can be used along with the VG config:
Telco – PRI – GW – MGCP – CUCM – SIP – ATA187 – Fax/Modem [Can do both Passthrough and T38]
Config for GW doing Modem Passthrough:
no ccm-manager fax protocol cisco
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711ulaw
Config for GW doing T38: no ccm-manager fax protocol cisco               no mgcp fax t38 inhibit  mgcp package-capability fxr-package mgcp default-package fxr-package no mgcp fax t38 ecm mgcp fax t38 nsf 000000
HTH.
Harmit.
Hi, thanks for your quick replies!
We currently use SIP instead of MGCP
Hi Fikri,
  fax nsf 000000
  fax-relay sg3-to-g3
HTH.
Harmit.
Hi Harmit,
We did the following configuration as you guided but the transmission is still not okay
dial-peer voice 76 voip
translation-profile outgoing FAX
huntstop
destination-pattern 888883006
session protocol sipv2
session target ipv4:10.231.103.101
session transport udp
voice-class codec 99
fax protocol t38 version 0 ls-redundancy 2 hs-redundancy 0 fallback none
Hi Fikri,
Did you try an incoming fax or outgoing? The dialpeer is an outgoing dialpeer. Is that the CUCM IP address: 10.231.103.101? So your callflow should be:
Telco – PRI – GW – SIP – CUCM – SIP – ATA187 – Fax
Is the above correct? Did you upgrade to the latest firmware on the ATA? Kindly capture the following:
++     Can you take packet captures from the ATA and the voice gateway by spanning the switchports where they are connected?
++     Detailed CUCM SDI and SDl traces from all nodes in the cluster
++     Screenshot of the ATA config page as well as the SIP trunk config page on CUCM.
++     The following debugs from the VG:
debug voip ccapi inout
debug ccsip messages
debug voip vtsp all
debug isdn q931
Collecting debugs in Router logging buffer
Router#configuration terminal
Router(config)#no logging console
Router(config)#service timestamps debug datetime msec
Router(config)#logging buffered debugging
Router(config)#service sequence
Router(config)#no logging rate-limit
Router(config)#exit
Router#
Please capture the above for one call along with the calling, called party numbers, timestamp and symptom observed. Apologies for the amount of data required but it is necessary to troubleshoot. :-)
Harmit.
Hi Harmit,
After applying the correct config and upgrading to the firmware 9.2.3.1, which is the latest release, we can send and receive fax through T.38, everything works fine, thank you for your guidance and support!
Fikri
Hi Fikri,
Excellent news! Glad to hear that! Could you please mark this discussion as answered to help others who refer to it as well? Appreciate it. Happy New Year!
Harmit.
Can you please share the corrections that you made to fix this issue or kindlyshare the working config from the VG.
