취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
How to download the DMA
So, where do I find the DMA? All the links I have go to the URL below and I can't find the Data Migration Tool. Can someone give me a url and a path? Thanks.
http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=278875240
2 응답 2
craiglcve
Level 4
Level 4
DMA is located under the Communications manager software page.
Voice and Unified Communications > Cisco Unified Communications Manager Version 7.1 > Unified Communications Manager Data Migration Assistant
It is version specific. For example if you were upgrading to version 7 you would go to that page you posted and then down to Cisco Unified Communications Manager Version 7.1 and you will see it in the Callmanager 7.1 software.
Thanks, I found it. The full path I took is below. The file never came up in the search. In any case, thanks.
Voice and Unified Communications > Ip Telephony> Call Control>Cisco Unified Communications Manager (CallManager)>Cisco Unified Communications Manager Version 7.1>Unified Communications Manager Data Migration Assistant
