Hello, guys.
Sorry if this topic is a duplicate, but I really haven't found clear solution for my question.
I want to setup load balancing to UC application pairs. Including CUIC, CUCM, Finesse, CUP, CUC.
I have set Haproxy solution with pass-through mode. It works fine but I need to accept server ssl certificate every new session.
To avoid this I think I have to implement SSL termination on my load balancer. To do that I believe I have to import certificates/private key pairs to load balancer.
I have found the way to export certificate from Cisco Unified OS Administration > Security > Certificate management, but how can I get a private key? Is it possible without breaking the OS?
Maybe you can suggest other possible ways to implement load balancing and reliability between these applications.
Any help appreciated.
