05-10-2016 10:51 AM - edited 03-17-2019 06:51 AM
I am configuring CUCME and CUE on a 2951 router for a customer. I have 7945 and 7821 running on sip. The IP phones can call each other and other features seem to work fine. However, the voicemail settings on CUE or CUCME could have an issue. I can reach voice mail on extension 199 but can’t retrieve messages from voice mail when prompted to select options on dial buttons. Please help. Attached are my configs.
05-10-2016 11:24 AM
How CUCME is communicating with CUE,I can't see a dial-peer for unity?
05-10-2016 12:48 PM
Can you try by adding maximum sessions under dial-peer 1 for voicemail.
05-12-2016 09:06 AM
Hi,i configured maximum-sessions under dial-peer 1 for voicemail but i still when i press the buttons nothing happens,this is implementation for site 2 but same issue.Please find the attached files below.Thanks.
05-10-2016 01:22 PM
Thanks for your response.sorry i didnt upload the updated file but i have just done that.should the dial-peer to voice-mail be enough for interaction btw cue and cucme?
05-10-2016 01:22 PM
OK looks better now:).
you can try adding dtmf -relay type in CUE.( I believe SIP-notify in this case).
config t
ccn subsystem sip
dtmf-relay sip-notify
I believe when you press buttons nothing happens ?
05-11-2016 09:11 AM
Yes,when the buttons are pressed nothing happens.I am configuring another voice router for site 2 and still having the same problem even after configuring 'dtmf-relay sip-notify' under ccn subsystem sip.Attached are configs with dtmf-relay sip-notify configured.Thanks.
05-11-2016 09:11 AM
Please run below debugs during the failure scenerio.thanks
Ccme# debug ephone detail
Ccme# debug ccsip messages and debug voip rtp session named-event
05-12-2016 09:18 AM
Hi,configuring dtmf-relay rtp-nte in ccn subsystem sip,voice register pool and dial-peer instead of dtmf-relay sip-notify did the trick.Thanks for your help.
05-12-2016 09:18 AM
Good job.
So in this case it looks like phone was sending RTP NTE only.
