12-13-2017 03:51 AM - edited 03-17-2019 11:47 AM
I have a phone which is a member of several hunt groups (i.e. they are a member of several distinct line groups, which are all part of several distinct hunt lists and hunt pilots).
How can I find out which Line Groups they appear in?
Solved! Go to Solution.
12-13-2017 03:56 AM
You go to the DN and then you select: Related Links -> Dependency Records -> Go. You will there see the list of Line Groups it is connected to.
Dependency records should be enabled in Enterprise Parameters.
12-13-2017 03:56 AM
