10-20-2016 04:40 PM - edited 03-17-2019 08:25 AM
How to get access to web configuration for a IP Phone 7940?. I tried using
Please advise
10-20-2016 06:01 PM
Is this Cisco CUCM/CUE or third-party callmanager?
10-20-2016 06:03 PM
First of all you can not configure any Cisco IP phone from by going to its web page - you can either do it from a call control server which push the configs to phone or have to edit the xml file and then supply the files to phone via tftp.
If you have got call control as CUCM - phone config is done in CUCM, web access to phone can be enabled from CUCM device page- change the Web Acess parameter to enabled if its not.
If CME is your call control - you will configure the phone from CME and can enable web access from CME under the Telephnoty-service (you can google for exact commands)
If its any free IP PBX: And you are looking to set some parameters, you will need to modify XML file.
Ref: http://www.voip-info.org/wiki/view/Asterisk+phone+cisco+79x1+xml+configuration+files+for+SIP
-Terry
Please rate all helpful posts
