How to have a Webservice accept a call with raw call stream
salman.hasrat
We’re building an application that will accept a call and based on user speech will interface with our system and perform certain actions.
My question is how can I hook into CUCM to be able to accept the call and get the raw call voice stream to be able to analyze it? Ideally, a web service will need to “accept” the call along with the raw call stream.
thanks!
Hi Salman,
Most of web applications uses CTI control to manage a line and through it make and receive calls. The main thing  is to provide the application the rigth permission to use/control the telephony part in CUCM. This can be accomplished by creating an End/Application user giving him the End User and CTI Control permission.
Anyway your UC engineer/partner  can dig with you into the application you are intended to realize
Hope this helps
Carlo
Please rate all helpful posts "The more you help the more you learn"
