How to register CUE AA Pilot Number with SIP register server?
dmitrinik
Beginner
Beginner
Hello all,
Can anyone please explain to me how to register an E.164 number which is assigned to a CUE AA with provider's SIP register server?
All online documentation examples only show how to forward calls to AA coming from PSTN either over PRI trunks or analog ports using the PLAR command.
Thank you very much.
Vivek Batra
Engager
Engager
IMO, you can follow simple SIP registration process to register the desired number with service provider, for instance it is AA number in your case.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube_sipsip/configuration/xe-3s/cube-sipsip-xe-3s-book/voi-sip-trunk-reg.pdf
- Vivek
Vivek, the pdf file you've provided is for IOS-XE platforms, and won't work for me.
I'm using Cisco 2821 with CME and CUE.
Thank you.
Below is the good sample configuration;
http://www.innotechcg.com/resources/HowTo/Cisco%20CME%20SIP%20Trunk%20Configuration.pdf
- Vivek
Recognize Your Peers
