ā10-26-2011 01:57 PM - edited ā03-16-2019 07:43 AM
Can you please provide the steps required to configure integrated messaging on Unity Connect 8.5?
What are the instructions/steps for configuration of IMAP on Exchange 2003 for integrated Messaging?
What tasks need to be configured on Unity Connect?
ā10-26-2011 05:52 PM
The guide that is available on CCO has all the info.
www.cisco.com/en/US/partner/docs/voice_ip_comm/connection/8x/unified_messaging/guide/85xcucumg0
20.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
ā10-26-2011 08:02 PM
Thanks for the link
Based on the document with cuc 8.5 I can only setup unified Messaging, is that correct?
If not how would i configure Integrated messaging using IMAP?
