How to setup Linksys SPA3000 fxo line with callmanager
Attiq
i have linksys spa3000 voice gateway which is registered with call manger 7.0,  fos working properly with internal ip telephony network but i can not able to call outbound via fxo.
line 1 registered with 2020 ext.
please guide me to setup fxo with callmanger??
Jaime Valencia
That depends on the protocol you want to use, there are several guides already on cisco.com that cover analog trunk configurations, have you reviewed any of them???
java
if this helps, please rate
Thanks for you reply ..
i have setup SIP trunk for outbound call and cisco 1841 router as h323 gateway for internal calls. my internal ip telephony setup working properly with analog phone exts. but i can't enable to call through pstn line to outbound.
