How to update Numbering Plan file in CUCM 7.1?
dfokin
Hi!
Since last update of Russian Numbering Plan passed a long time. Many things are changed since then. Now we are able to choose alternate carrier for the call, the numbering plan was slightly re-arranged, some area codes are no more used. Current Numbering Plan is well described here: http://en.wikipedia.org/wiki/Telephone_numbers_in_Russia.
Although, Cisco with their version 1.1(4) of russian NP still thinks, that we are in 2005. Currently I am trying to implement 9.@ dialing in my cluster and I need most current version of NP. Is it possible to edit NP file to make it more current before installing into CUCM?
Thanks in advance!
Jaime Valencia
No, it's not possible to change the NP within CUCM.
If the current dial plan on CCO is not really updated to reflect changes reach your account team so they can engage with the BU and have them update it.
Otherwise it means you'll have to manually create it using route patterns.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
