08-11-2011 03:34 AM - edited 03-16-2019 06:25 AM
hi all,
how to Verify that the DSPs are in digit collection mode in cisco ios router , please explain me the process
Karthik
08-11-2011 12:44 PM
hi all,
please help me on this
Karthik
08-11-2011 11:05 PM
You can maybe try to use debugging command on the router like "debug vpm dsp"
To show messages from the digital signal processor (DSP) on the voice port module VPM) to the router, use the debug vpm dsp command in privileged EXEC mode. To disable debugging output, use the no form of this command.
debug vpm dsp
no debug vpm dsp
This command has no arguments or keywords.
Privileged EXEC
The debug vpm dsp command shows messages from the DSP on the VPM to the router; this command can be useful if you suspect that the VPM is not functional. It is a simple way to check if the VPM is responding to off-hook indications and to evaluate timing for signaling messages from the interface.
The following output shows the DSP time stamp and the router time stamp for each event. For SIG_STATUS, the state value shows the state of the ABCD bits in the signaling message. This sample shows a call coming in on an FXO interface.
The router waits for ringing to terminate before accepting the call. State=0x0 indicates ringing; state 0x4 indicates not ringing.
ssm_dsp_message: SEND/RESP_SIG_STATUS: state=0x0 timestamp=58172 systime=40024
ssm_dsp_message: SEND/RESP_SIG_STATUS: state=0x4 timestamp=59472 systime=40154
ssm_dsp_message: SEND/RESP_SIG_STATUS: state=0x4 timestamp=59589 systime=40166
The following output shows the digits collected:
vcsm_dsp_message: MSG_TX_DTMF_DIGIT: digit=4
vcsm_dsp_message: MSG_TX_DTMF_DIGIT: digit=1
vcsm_dsp_message: MSG_TX_DTMF_DIGIT: digit=0
08-11-2011 11:52 PM
hi phooghen,
thanks for your response
regards
karthik
