hunt list for operator
hamid ghani
hi guys,
please tell the procedure for hunt list/hunt group.
i have one extension 4444 for three operators and i am using the 0 with translation pattern.
what configuration steps i can use???
Yes, you can set the DN in the hunt pilot as 0 and ring the members of the line group.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
You configure the line group, add that line group to a hunt list and use that hunt list with the hunt pilot.
java
java
hi javalenc,
thanks for your reply, if i use line group and then hunt poilet then may be i dont need 0 to be translated to 4444
in hunt poilt i wil put 0 with list of operators??
waiting for reply
java
java
