I am gettin a busy tone when dialing 661 area code in call manager 4
skavarian
When I dial 661 area code, I am getting fast busy tone.  I've looked at the translation pattern, I do have 9.1XXXXXXXXXX which covers all area codes.  I have no problem dialing 818 or any other area code.  I even went in and copied the pattern to create another one and modified the pattern to be 9.1661XXXXXXX.  that didn't help either.   Any suggestions?
Shant
Jaime Valencia
Is that the pattern you're hitting for those calls?
Or is there something more specific?
Sent from Cisco Technical Support Android App
java
if this helps, please rate
