IP Telephony and Phones
Labels
Dear All,I am running call manager 9.1Is there a way i can track which ext is calling where and the time duration.Kindly let me know if this option is available in call manager 9.1Will be very thankful for your support.Regards,Malik.
tiger_401 by Level 1
  • 537 Views
  • 3 replies
Dear All,I am running call manager 9.1I have a question that when you want to make a call to any other internal ip phone user for example you press the first two digits of the other extension the i phones displays the extensions in the drop down list...
  • 1387 Views
  • 3 replies
Dear Experts,1) I would like to Add '0' to an 10 digit incoming call because i am getting only 9 digits from the SP on AnalogLine terminated on FXO using H323 Protocol with CUCM 8.5 this line is dedicated to the manager for both incoming and outgoing...
johntim20 by Level 1
  • 412 Views
  • 1 replies
hello,I tried to upgrade the software of UC520 to the version 8.6.1 but the phones 79xx don't accept the new firmware 9-1-1 so i tried to upgarde the firmware to another intermediate version 8-5-2 but they can't register and in the firmware version i...
Hi everybody.1)When a Cisco ip phone boots up, it gets its configuration file from tftp server. This configuration specifies the load( firmware) the phone should be running.I also found the load setting under " default setting" on CUCM 7. My question...
sarahr202 by Level 5
  • 419 Views
  • 2 replies
