07-21-2014 03:51 AM - edited 03-16-2019 11:28 PM
hi,
I am in need of an explanation of the NAT concept.
I have a single public IP address and I am trying to set up cameras over the internet. Do I open ports per camera (and how) or is the following command sufficient.
(config)#access-list 1 permit 10.10.0 0.0.0.255
(config)# ip nat inside source list 1 pool IPCAM overload
(config)# ip nat pool IPCAM 11.22.33.44 11.22.33.44 netmask 0.0.0.255
where 11.22.33.44 is my only public address
and 10.10.1.0/24 is the internal network
nat inside interface=10.10.10.1
nat outside interface=11.22.33.44
Thanks!!
07-21-2014 04:27 AM
Hi ,
If you are accessing your IP camera locally using port number http:10.10.10.1:8080 or http:10.10.10.1 ,use below command to NAT your IP camera for Public IP address on 8080
Post Port Nating you access it http:11.22.33.44:8080 or http:11.22.33.44
for 8080
ip nat inside source static tcp 10.10.10.1 8080 11.22.33.44 8080
for 80
for other port number xx is service port number .
ip nat inside source static tcp 10.10.10.1 XX 11.22.33.44 XX
Sandy
07-21-2014 05:13 AM
Hi to add on that,
Check your cameras specifications for it may require more ports to be forwarded
You may be able to view your console, but no video/audio feed might be displayed.
