IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6030 Views
  • 14 replies
                   Hello, we have 99xx Phones which uses G.722 as Codec within CUCM 8.5.                   When i use Jabber for Windows Client 0.0.1 as softphone the codec is switched back to G711 (Call from Softphone to 99xx Phone)                 ...
mjuch by Level 5
  • 2296 Views
  • 4 replies
Hi all...I'm a new member of CUCM 8.0.3.20000-2I have problem about fast dial or speed dial (I'm not understand what's it mean)- Model phone: 7945- Server: CUCM 8.0.3.20000-2- I wish: when I press 101 on phone then direct connect to 903591991 (cellph...
binhnbp01 by Level 1
  • 188 Views
  • 2 replies
Hi Guys, I met a problem when integrating with Avaya systems. To make it easily undersood, I just simplified the diagram like beflow. Please kindly share your advice for this configuration. Phone1-----CUCM1---------FW--------Avaya CM----Phone2       ...
Gary Tong by Level 1
  • 385 Views
  • 4 replies
I have a user who logs into CAR and tries to pull records. CAR returns no data.I then log into CAR (I'm Admin) and run a CDR report on their extension and get over 100 hits for the same time period.So why are they not seeing any data for the exact sa...
k6lw by Level 4
  • 337 Views
  • 1 replies
Hello,I am following the below link for CUCM 9.1http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7975G_7971g-ge_7970g_7965g_7945g/9_0/english/admin_guide/P747_BK_W06BD6D9_00_adminguide_7945-7965-7970-7971-7975/P747_BK_W06BD6D9_00_adminguide_...
adamgibs7 by Level 6
  • 3797 Views
  • 8 replies
Resolved! BRI on C881-V-K9
I cannot find in the data sheet of C881-V that the BRI interface could be used as ISDN network side function or not.Can I set these parameters?!interface BRIx isdn switch-type basic-net3 isdn protocol-emulate network isdn layer1-emulate network!Thank...
