08-11-2015 12:08 AM - edited 03-17-2019 03:56 AM
I've tasted the lines using an analog phones and I am able to see the caller Id on the display.
08-12-2015 10:16 PM
Have you tried configuring the "caller-id enable" command on the FXO port receiving the call?
08-13-2015 03:12 AM
Hi Jonathan,
Thanks for your replay I have tried many config combination along with shut no shut
voice-port 1/0/12
supervisory disconnect dualtone mid-call
supervisory custom-cptone FXO
echo-cancel coverage 64
cptone BE
timeouts wait-release 1
connection plar opx 240
impedance complex2
description Direct No. 4936251
caller-id enable
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
08-13-2015 03:37 AM
Can you please explain the topology and share the output of debug voice ccapi?
08-13-2015 04:07 AM
08-13-2015 09:07 AM
Use cptone as US and caller-id alerting ring 1.
Then share the debug voice ccapi and debug cch323 h225. Share the calling/called numbers
08-13-2015 08:33 AM
Can you try this?
caller-id alerting ring 2 shut no shut
08-13-2015 08:37 AM
Hi Eric,
Yes I've already tried that one also ring 3 and 4
Thank you
Kassim
08-13-2015 08:42 AM
Hi Kassim,
Hmm, then my guess is it has something to do with the cptone that prevents the router from parsing the caller ID correctly.
cptone BE
Can you explain why you have a custom cptone and the Belgium cptone as well? Is this a setting you normally do? and for what purpose
