i have configured 3 phone lines ,but only two phones lines are working ?what seam to be the problem
CSCO12245191
description * * * Not In Use * * *
voice-port 0/1/0
connection plar 222033436
voice-port 0/1/1
connection plar 222033437
voice-port 0/1/2
connection plar 222033438
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 pots
description * * * "13 digits"
destination-pattern .............
direct-inward-dial
port 0/1/0
forward-digits all
dial-peer voice 2 pots
description * * * "9" Digit Mobile Dialling line 1 * * *
destination-pattern 9........
direct-inward-dial
port 0/1/0
forward-digits all
dial-peer voice 11 pots
direct-inward-dial
port 0/1/1
forward-digits all
dial-peer voice 222 pots
direct-inward-dial
port 0/1/1
forward-digits all
dial-peer voice 33 pots
direct-inward-dial
port 0/1/2
forward-digits all
dial-peer voice 333 pots
description * * * "9" Digit Local Dialling line 1 * * *
destination-pattern 2........
direct-inward-dial
port 0/1/0
forward-digits all
dial-peer voice 444 pots
description * * * "9" Digit Local Dialling line 2 * * *
direct-inward-dial
port 0/1/1
forward-digits all
dial-peer voice 222033436 voip
description switchboard Phone PLAR -- send call to CUCM
destination-pattern 222033436
session target ipv4:10.131.184.203
dtmf-relay h245-alphanumeri
c
codec g711ulaw
fax rate disable
dial-peer voice 222033437 voip
destination-pattern 222033437
dtmf-relay h245-alphanumeric
codec g711ulaw
fax rate disable
dial-peer voice 222033438 voip
destination-pattern 222033438
codec g711ulaw
fax rate disable
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password cisco
login
transport input telnet ssh
scheduler allocate 20000 1000
end
Router#
CSCO12245191
222033437 are working but the 222033438 is not.
