I wanted to Change voice message recording format from G.711 mu-law to G.729a but in order to do this I need to:
get this sl_g729a_setup.exe fro mthe cisco unity connection utility dvd (8.5 or 8.6)
where can I download this dvd
To Install the G.729a Codec for Cisco Unity on a Subscriber Workstation That Does Not Have ViewMail Installed
Step 1 On Cisco Unity DVD 1 or CD 1, browse to the Utilities directory.
Step 2 Copy the Sl_G729a_setup.exe file to the directory of your choice on the network or to a disk.
Step 3 Administrators or subscribers can install the codec from the network or from the disk:
a. Confirm that the subscriber workstation is using a Windows operating system and that a compatible audio player is installed.
b. Double-click Sl_G729a_setup.exe, and follow the on-screen prompts.
c. Restart the subscriber workstation for the codec change to take effect.
