IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5548 Views
  • 14 replies
I have just installed some 7925's on our network. Every ringtone on them sounds exactly the same as it does on a 7975, except one (my favorite =P) which is the CTU24 ringtone. Could there be any reason why this one ringtone does not work properly on ...
CCME extension assigner was dialed today to swap out a broken phone, it normally works fine. The following is now occuring.Dial the extension number, greeted with "Welcome CME EA, enter password". After dialing the first digit of the password (or any...
hi,i have a 2901 with 15.2(2)M and one PVDM3-16 installed. I try to get working an ad-hoc conference but when i enter the commanddsp profile 1 conference maximum session <0-0>0 sessions? --------------------------------------------------------------...
HiWe have a DDI range where a few numbers need to be re-directed to a QSIG trunk using more specific dial peersNow we have the "problem" that on the incoming dial-peer the DDI range is translated to our internal numbering plan.is there a way to exclu...
kpintens by Level 1
  • 484 Views
  • 2 replies
Resolved! Re-direct a call
HiWe have a H323 gateway and we need to re-direct/deflect certain DDI number to a QSIG trunk on the same gateway.In ohter words, certain DDI numbers will go to IP Phones but a few numbers in that range need to go to the legacy PBX via QSIG (or other ...
kpintens by Level 1
  • 365 Views
  • 2 replies
Trying to do some things on CUCM 8.6.2a with CIUS tablets.  Can't find documentation on how to do the following things:1.  While on a video call, how to you get the CIUS tablet to switch over and use the REAR camera on the call (i.e. how to switch be...
Hi there,I have H323 gateway with FXO card, When I am making a call from CCM to PSTN through certain port number, call gets out but I hear call cancelation beeps.  When I connect analog phone to this line I can make the calls successfully. what could...
Hello everyone.Some time ago someone asked a question about a problem with a SIP ringback issue.  I am having a problem that just started happening.  We have a SIP trunk to our provider (Paetec) and we have never had a problem before.  In the last mo...
All,     I am looking for an auto attendant to pair with my CUCM 7.x lab. I want to be able to have an auto attendant that will allow me to either dial an internal extension, or dial a full 10 digit number that goes back out to the world via my SIP t...
