I need your help configuring Cisco Jabber
cmchamba1
I need your help configuring Cisco Jabber 4.4.4 xperia z2 ....
No works to make calls , I have chat only
Jaime Valencia
The jabber for android configuration guide lists all the details and configuration required in order to make it work, have you already reviewed it and followed the instructions???
If not, that's the very first thing to do.
java
if this helps, please rate
I can not find the settings for Xperia z2, I made a normal configuration galaxy s 4 and works all right, while in the xperia x2 no calls work
xperia z2 , sorry
The settings in CUCM are the same for any phone, make sure that such model is in the supported model list, with the right Android version, phones not listed are not guaranteed to work.
If it's supported, gather a PRT to see what the problem might be.
java
