01-04-2008 09:32 AM - edited 03-15-2019 08:03 AM
I have an ICT between two clusters A and B - it works one way A-B but not the other B to A- I get fast busy. The DNA on site B shows the call hitting the ICT and sending the correct extension number but still getting fast busy. I`ve tried it with a site code being stripped off on site A and just with extensionsn numbers but still not working
01-04-2008 11:35 PM
Check Incoming CSS of the Incoming ICT.
Check the Device Pool of ICT.
Check this URL
01-07-2008 03:05 AM
Thanks, I did not have the corrrect region settings- should stop using my phone as a test phone!
