09-21-2015 04:31 AM - edited 03-17-2019 04:21 AM
Hi All,
We are running IM&P 10.5 with HA enabled on the subscluster. When we enable the IM&P Service for new users,they become unassigned users in Presence.{ Existing users are working fine]
Same behavior happening for existing user, when we disable & enable the IM&P service.
I have tried with restarting the sync service but no luck. Found from sync logs. user are mapped to cups db without any issue.
1) what are the logs we need to check to troubleshoot on this ?( I thing presence engine responsible for assign the user in nodes)
2) what are other possible reasons or other things need to check ?
3) Presence server status in the sub cluster will affect the user assignment ?
current state of the subscluster.
Server State Reason
Publisher Running in backup node Initialization
Subscriber Failed Over Initialization
Thanks in Advance !!!!!
09-21-2015 04:26 PM
When we enable the IM&P Service for new users,they become unassigned users in Presence.{ Existing users are working fine] >> For this I believe the parameter is in the Enterprise Parameters
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/im_presence/configAdminGuide/10_5_1/CUP0_BK_CE43108E_00_config-admin-guide-imp-105/CUP0_BK_CE43108E_00_config-admin-guide-imp-105_chapter_00.html#CUP0_RF_UE9F2912_00
For the question 3.
I believe it is Initializing stage and should come back to normal state once all the services are up and running.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmcfg/CUCM_BK_C95ABA82_00_admin-guide-100/CUCM_BK_C95ABA82_00_admin-guide-100_chapter_0101.html#CUCM_TK_E26FE885_00
09-21-2015 07:49 PM
Hi Wilson !
Thanks for your reply..
1) By default user assignment is "Balance" mode where user assignment will take care automatically.
2) Presence nodes are in steady state . Here reason is showing as initialization since i restarted the SRM service.
09-21-2015 10:44 PM
Hi wilson !
Users assigned to the Node , once i done the fallback in server action.
As you said, server state should be normal. But not sure it's mandatory in all the fail over scenario's.
User assignment process are captured in presence engine logs.
Thanks.....
