Import CUCM extensions into AD IP Phone field
mtavarez
Would anyone have any idea as to how I can import the CUCM extension or UnityCN extension into the IP Phone field in AD? I am looking for a way to automatically update user extension information within AD from CUCM and\or UnityCN versions 8.6.
Manny
Jaime Valencia
CUCM and CUC only pull info. They do not push info to AD, you would need to build some kind of script to get the info from CUCM and then push it into AD
java
if this helps, please rate
PTS
Please check attached document of MARS AD CUCM Provisioning application which automatically updates CUCM Extensions in AD
