07-25-2018 01:31 AM - edited 03-17-2019 01:14 PM
Dears
we have this scenario
CUCM Cluster (Pub & Sub ) ----SIP TRUNK----CUBE----SIP Provider .
We face an issue with incoming calls with this error messages
Cause Value=127
Also outbound calls failed with reason code
Reason: Q.850;cause=102
Please check attached
Show run of CUBE
logs of below debugs in case of inbound and outbound calls
debug voip ccapi inout
debug ccsip messages
debug voip rtp session named-event
also find output of
show sip-ua timers
show sip-ua retry
show sip-ua min-se
Solved! Go to Solution.
07-26-2018 02:29 AM
07-27-2018 02:38 AM - edited 07-27-2018 02:57 AM
Issue has been Solved
Telco informed us that we use source port different than 5060 ,so we configure sip source port to be 5060 be below commands
voice service voip
sip
isten-port non-secure 5060
listen port Change will be effective once the SIP service is re-started
call service stop
no call service stop
Also we add this commands
sip-ua
connection-reuse
07-25-2018 01:56 AM
07-25-2018 03:14 AM
Hello Sreekanth Narayanan
Thanks for your replay
Please note that I can ping SIP Proxy Server IP address successfully .
and this SIP circuit was works fine on another IPPBX
07-25-2018 09:24 AM
07-25-2018 11:47 AM
Kindly check below logs of incoming call , i noticed that , called number has been repeated .It must be
69326900 but in logs become 6932690069326900 .
Please advice
Set Up Event Sent;
Call Info(Calling Number=91239850(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=6932690069326900(TON=Unknown, NPI=Unknown))
Jul 25 07:52:23.677: //650/8024AC1B82FD/CCAPI/cc_process_call_setup_ind:
Event=0x7FF44E2BA4E8
Jul 25 07:52:23.677: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 6932690069326900
07-25-2018 11:25 PM
07-26-2018 12:16 AM
07-26-2018 01:15 AM
07-26-2018 01:32 AM
07-26-2018 01:43 AM
07-26-2018 02:03 AM
07-26-2018 02:29 AM
voice service voip
sip
call service stop
sip-ua
connection-reuse
07-27-2018 05:48 AM
