Hi All Can I export configuration using BAT from cucm 8.5 and import this data to cucm 11.5? TIACristian
How to install devicepack for cme 8.6 using CLI. I am getting info about gui installation but in my gui there is no option for install/upgrade. Router#sh flash: -#- --length-- -----date/time------ path1 59803980 Feb 22 1907 17:31:44 +00:00 c280...
Hello, We are looking at utilizing RedSky only for e911 mainly because our phones are mounted and no concern of phone movement. I have a question regarding call back from the PSAP to the origination of the 911 call in case of a hangup. Is it possi...
Hi, can anyone confirm if there is any option for headset with 3905? is bluetooth supported? or will the handset jack work for wired headset or some bluetooth enabled headset? thanks in advance.
Hey I'm asking for some informations about DX-650 if any one have responses :- DX-650 support IPMA ??- DX-650 support Mobile Connect ?? Best Regards
Are there any known issues regarding remote destination profiles and cell phones linked to shared lines? We have a scenario where we have a cell phone that is linked to a shared line and the mobility is enabled, when the cell phone is on the shared ...
At my office we started using the CIPC. I wanted to see if there's an updated version of this and I come to a page saying it's EOL and not supported anymore. Is there another Cisco Softphone application instead of CIPC ?
So I have an MGCP gateway that randomly fails over and shoots an RTMT alert that is loses connection however keep alives are sent and are responded to. I looked at the logs and noticed when this happens the router sends a RSIP message out only 7 seco...
Hi All When you go from the CUCM voip phone and out to the PSTN, can anyone tell me what codec it normally gets transcoded to when sending out to the PSTN?
Hi, End user has a CUCM 10.5 with gateway 2921 with normal operations. User has SCCP and SIP IP phones, they can receive and makecalls internal and also with PSTN (currently with 1 E1). In the last week end user receive a sIP trunk for testing pu...
Hi, I'm currently working on a mobile remote access design for CUCiLync, i believe this is the same discovery process as Jabber. The client has split domain: Internal Domain = domain.net External Domain = domain.com They want all clients to log...
Dear All, We are facing issue with Call recording with Cisco SIP phones registered on CUCM 11.5 We are using NICE Call Recording. Call recordings on the NICE Recorder are not playable. below is the analysis of the test call. Below is the ca...
Hello, we are running a CUCM 8.5 cluster and we have a Cisco 2901.The 2901 is our SRST Reference (SRST Reference = Use Default Gateway)We have SCCP Phones and SIP Phones (9951) in that site (same subnet)The SCCP Phone and they register fine, but the ...
I have an employee who would like to be able to see the line status of her boss from the display of her CP-8841 phone. Although she could do this in Jabber, she would like to use the phone only if possible. Is there a way to do this? Our organization...
Hello, We're setting up an extension that needs direct inward dial, but it doesn't seem to be working. Is this enabled in the call manager or is it something that needs to be set up with our phone company? Thanks.
Subject | Author | Posted |
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-22-2025 08:53 PM | ||
05-21-2025 06:23 AM | ||
05-16-2025 12:03 AM |
User | Count |
5 | |
4 | |
2 | |
2 | |
2 |
