Inbound Calls not working
aniket0422
Level 5
Level 5
Hello Guys,
Call Flow is -- PSTN --> PRI --> Voice RTR --> SIP Trunk --> CUCM --> IP Phone.
When we dial from outside calls are not getting connected.
Error Message : "Unable to find a device handler for the request received on port 63565 from 100.201.0.74
Below are the Q931 and CCSIP debugs. Can anyone please help to identify cause.
LUCKNOWBO-RTR#8~
003239: *Feb 18 11:50:54.260 UTC: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x1300
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838D
Exclusive, Channel 13
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x0183, '09987527822'
Plan:ISDN, Type:Unknown
Calling Party Number i = 0x0180, '9987527822'
Called Party Number i = 0x81, '4920999'
Sending Complete
003240: *Feb 18 11:50:54.260 UTC: ISDN Se0/1/0:15 Q931: Received SETUP callref = 0x9300 callID = 0x004B switch = primary-net5 interface = User
003241: *Feb 18 11:50:54.265 UTC: //81833/63CE0E82804E/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:3560@10.50.2.11:5060 SIP/2.0
Via: SIP/2.0/UDP 100.201.0.74:5060;branch=z9hG4bKDDAA28
Remote-Party-ID: <sip:9987527822@100.201.0.74>;party=calling;screen=no;privacy=off
From: <sip:9987527822@100.201.0.74>;tag=47A455DE-32C
To: <sip:3560@10.50.2.11>
Date: Thu, 18 Feb 2021 11:50:54 GMT
Call-ID: 63CEAAAA-711611EB-889BB616-47B93090@100.201.0.74
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1674448514-1897271787-2152639562-1459327680
User-Agent: Cisco-SIPGateway/IOS-16.4.2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1613649054
Contact: <sip:9987527822@100.201.0.74:5060>
Expires: 180
Allow-Events: kpml, telephone-event
Session-ID: 4e61954be6d052d39afac7d04a6b329a;remote=00000000000000000000000000000000
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 243
v=0
o=CiscoSystemsSIP-GW-UserAgent 6 2972 IN IP4 100.201.0.74
s=SIP Call
c=IN IP4 100.201.0.74
t=0 0
m=audio 8288 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
003242: *Feb 18 11:50:54.266 UTC: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x9300
003243: *Feb 18 11:50:54.325 UTC: //81833/63CE0E82804E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Thu, 18 Feb 2021 11:44:01 GMT
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
003244: *Feb 18 11:50:54.327 UTC: //81833/63CE0E82804E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 503 Service Unavailable
To: <sip:3560@10.50.2.11>;tag=1613851967
CSeq: 101 INVITE
Warning: 399 F5-DC-CUCM-SUB-01 "Unable to find a device handler for the request received on port 56194 from 100.201.0.74"
Content-Length: 0
003245: *Feb 18 11:50:54.328 UTC: //81833/63CE0E82804E/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x7F74B4C01B98
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 9987527822
Called Number : 3560
Source IP Address (Sig 😞 100.201.0.74
Destn SIP Req Addr:Port : 10.50.2.11:5060
Destn SIP Resp Addr:Port : 10.50.2.11:5060
Destination Name : 10.50.2.11
003246: *Feb 18 11:50:54.328 UTC: //81833/63CE0E82804E/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 100.201.0.74
Source IP Port (Media): 8288
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
003247: *Feb 18 11:50:54.328 UTC: //81833/63CE0E82804E/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 38
Disconnect Cause (SIP) : 503
003248: *Feb 18 11:50:54.330 UTC: //81833/63CE0E82804E/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:3560@10.50.2.11:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 00000000000000000000000000000000;remote=4e61954be6d052d39afac7d04a6b329a
Content-Length: 0
003249: *Feb 18 11:50:54.331 UTC: //81834/63CE0E82804E/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:3560@10.50.2.10:5060 SIP/2.0
Via: SIP/2.0/UDP 100.201.0.74:5060;branch=z9hG4bKDDB1D40
From: <sip:9987527822@100.201.0.74>;tag=47A4561F-2244
To: <sip:3560@10.50.2.10>
Call-ID: 63D895B1-711611EB-889DB616-47B93090@100.201.0.74
Min-SE: 1800
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Session-ID: 61e3b626282c569cb30f4b00b9c0bae4;remote=00000000000000000000000000000000
Content-Length: 246
v=0
o=CiscoSystemsSIP-GW-UserAgent 8384 2246 IN IP4 100.201.0.74
s=SIP Call
t=0 0
m=audio 8290 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
003250: *Feb 18 11:50:54.389 UTC: //81834/63CE0E82804E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
003251: *Feb 18 11:50:54.391 UTC: //81834/63CE0E82804E/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:3560@10.50.2.10>;tag=830789803
CSeq: 101 INVITE
Warning: 399 F5-DC-CUCM-PUB "Unable to find a device handler for the request received on port 63565 from 100.201.0.74"
Content-Length: 0
003252: *Feb 18 11:50:54.392 UTC: //81834/63CE0E82804E/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7F74B4B9AE98
Destn SIP Req Addr:Port : 10.50.2.10:5060
Destn SIP Resp Addr:Port : 10.50.2.10:5060
Destination Name : 10.50.2.10
003253: *Feb 18 11:50:54.392 UTC: //81834/63CE0E82804E/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 8290
003254: *Feb 18 11:50:54.392 UTC: //81834/63CE0E82804E/SIP/Call/sipSPICallInfo:
003255: *Feb 18 11:50:54.395 UTC: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x9300
Cause i = 0x80A6 - Network out of order
003256: *Feb 18 11:50:54.396 UTC: //81834/63CE0E82804E/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:3560@10.50.2.10:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 00000000000000000000000000000000;remote=61e3b626282c569cb30f4b00b9c0bae4
Content-Length: 0
003257: *Feb 18 11:50:54.421 UTC: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x1300
003258: *Feb 18 11:50:54.422 UTC: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x9300
003259: *Feb 18 11:50:58.231 UTC: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.13.112.1:5060 SIP/2.0
Via: SIP/2.0/TCP 10.212.0.61:5060;branch=z9hG4bK3fc940357bce92
To: <sip:10.13.112.1>
Date: Thu, 18 Feb 2021 11:44:05 GMT
Call-ID: 990fb600-1ec18fe1-3d6cbb-3d00d40a@10.212.0.61
User-Agent: Cisco-CUCM12.5
CSeq: 101 OPTIONS
Contact: <sip:10.212.0.61:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
003260: *Feb 18 11:50:58.233 UTC: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.13.112.1>;tag=47A4655D-1C8B
Date: Thu, 18 Feb 2021 11:50:58 GMT
Server: Cisco-SIPGateway/IOS-16.4.2
CSeq: 101 OPTIONS
Allow-Events: telephone-event
Accept: application/sdp
Content-Length: 373
v=0
o=CiscoSystemsSIP-GW-UserAgent 1237 5854 IN IP4 100.201.0.74
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
003261: *Feb 18 11:51:00.519 UTC: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.50.2.11:5060;branch=z9hG4bK909272343a0094
Date: Thu, 18 Feb 2021 11:44:07 GMT
Call-ID: 9a40e300-1ec18fe1-8032d4-b02320a@10.50.2.11
CSeq: 101 OPTIONS
Contact: <sip:10.50.2.11:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
003262: *Feb 18 11:51:00.520 UTC: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.13.112.1>;tag=47A46E4D-1125
Date: Thu, 18 Feb 2021 11:51:00 GMT
CSeq: 101 OPTIONS
Content-Length: 372
v=0
o=CiscoSystemsSIP-GW-UserAgent 4058 271 IN IP4 100.201.0.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
003263: *Feb 18 11:51:00.830 UTC: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.112.0.29:5060;branch=z9hG4bKb48a7c7a2fdd
Call-ID: 9a40e300-1ec18fe1-b47f5-1d00700a@10.112.0.29
CSeq: 101 OPTIONS
Contact: <sip:10.112.0.29:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
003264: *Feb 18 11:51:00.831 UTC: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.13.112.1>;tag=47A46F84-1B70
CSeq: 101 OPTIONS
Content-Length: 373
v=0
o=CiscoSystemsSIP-GW-UserAgent 5719 7722 IN IP4 100.201.0.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
003265: *Feb 18 11:51:00.877 UTC: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.50.2.10:5060;branch=z9hG4bK7553535ca3f46d
Call-ID: 9a40e300-1ec18fe1-74c197-a02320a@10.50.2.10
CSeq: 101 OPTIONS
Contact: <sip:10.50.2.10:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
003266: *Feb 18 11:51:00.879 UTC: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.13.112.1>;tag=47A46FB3-94C
CSeq: 101 OPTIONS
Content-Length: 373
v=0
o=CiscoSystemsSIP-GW-UserAgent 4282 6997 IN IP4 100.201.0.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
003267: *Feb 18 11:51:02.400 UTC: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x1400
Standard = CCITT
Channel ID i = 0xA9838E
Exclusive, Channel 14
Sending Complete
003268: *Feb 18 11:51:02.400 UTC: ISDN Se0/1/0:15 Q931: Received SETUP callref = 0x9400 callID = 0x004C switch = primary-net5 interface = User
003269: *Feb 18 11:51:02.404 UTC: //81840/68A81EF4804F/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 100.201.0.74:5060;branch=z9hG4bKDDC1551
From: <sip:9987527822@100.201.0.74>;tag=47A475A9-105E
Date: Thu, 18 Feb 2021 11:51:02 GMT
Call-ID: 68A8945E-711611EB-88A7B616-47B93090@100.201.0.74
Min-SE: 1800
Cisco-Guid: 1755848436-1897271787-2152705098-1459327680
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1613649062
Expires: 180
Session-ID: 0e2446e56e785bbcb7c583e6262a63ca;remote=00000000000000000000000000000000
Content-Length: 246
v=0
o=CiscoSystemsSIP-GW-UserAgent 4443 7809 IN IP4 100.201.0.74
s=SIP Call
t=0 0
m=audio 8292 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
003270: *Feb 18 11:51:02.405 UTC: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x9400
003271: *Feb 18 11:51:02.458 UTC: //81840/68A81EF4804F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Thu, 18 Feb 2021 11:44:09 GMT
CSeq: 101 INVITE
Content-Length: 0
003272: *Feb 18 11:51:02.460 UTC: //81840/68A81EF4804F/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:3560@10.50.2.11>;tag=1858431792
CSeq: 101 INVITE
Content-Length: 0
003273: *Feb 18 11:51:02.461 UTC: //81840/68A81EF4804F/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7F74B4BB0F18
003274: *Feb 18 11:51:02.461 UTC: //81840/68A81EF4804F/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 8292
003275: *Feb 18 11:51:02.462 UTC: //81840/68A81EF4804F/SIP/Call/sipSPICallInfo:
003276: *Feb 18 11:51:02.464 UTC: //81840/68A81EF4804F/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 00000000000000000000000000000000;remote=0e2446e56e785bbcb7c583e6262a63ca
Content-Length: 0
003277: *Feb 18 11:51:02.464 UTC: //81841/68A81EF4804F/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 100.201.0.74:5060;branch=z9hG4bKDDD24F
From: <sip:9987527822@100.201.0.74>;tag=47A475E4-228B
Call-ID: 68B1BBE6-711611EB-88A9B616-47B93090@100.201.0.74
Min-SE: 1800
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Session-ID: ca6f985e99d45026ab40a3bcb70d7852;remote=00000000000000000000000000000000
Content-Length: 245
v=0
o=CiscoSystemsSIP-GW-UserAgent 8382 906 IN IP4 100.201.0.74
s=SIP Call
t=0 0
m=audio 8294 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
003278: *Feb 18 11:51:02.521 UTC: //81841/68A81EF4804F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
003279: *Feb 18 11:51:02.523 UTC: //81841/68A81EF4804F/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:3560@10.50.2.10>;tag=2018312928
CSeq: 101 INVITE
Content-Length: 0
003280: *Feb 18 11:51:02.524 UTC: //81841/68A81EF4804F/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7F74B4BCE518
003281: *Feb 18 11:51:02.524 UTC: //81841/68A81EF4804F/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 8294
003282: *Feb 18 11:51:02.524 UTC: //81841/68A81EF4804F/SIP/Call/sipSPICallInfo:
003283: *Feb 18 11:51:02.526 UTC: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x9400
003284: *Feb 18 11:51:02.527 UTC: //81841/68A81EF4804F/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 00000000000000000000000000000000;remote=ca6f985e99d45026ab40a3bcb70d7852
Content-Length: 0
003285: *Feb 18 11:51:02.552 UTC: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x1400
003286: *Feb 18 11:51:02.553 UTC: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x9400
% Bad IP address or host name% Unknown command or computer name, or unable to find computer address
aniket0422
Level 5
Level 5
This is resolved after binding all call manager facing dial-peer with below command.
dial-peer voice xx voip
voice-class sip bind control source-interface GigabitEthernet0/0/0.112
voice-class sip bind media source-interface GigabitEthernet0/0/0.112
Kaloyan
There are several possible causes:
1. You have configured the wrong IP address / port number on the SIP trunk in CUCM. Please verify that.
2. The trunk process is not running on that CUCM node (You can check the "Run on all active nodes" setting to see if that helps)
3. The trunk is marked as being down by CUCM due to OPTIONS ping messages being dropped in the network (try resetting the trunk to see if that's the issue)
There might be other causes to this issue but the above ones are the most common.
aniket0422
Level 5
Level 5
