Showing results forĀ
Search instead forĀ
Did you mean:Ā
Incoming call for the same city
haitham atef
  I have  a problem with the incoming calls from  the same city or province .
the incoming number has an area code although  that  call is coming  form the same city .
could you please tell me how can i solve this issue to remove the area code
5 Replies 5
ronpatel
Level 8
Level 8
You can use Calling Party Transformation Pattern Configuration  and resolve your issue.
regards
Ronak patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
how can i use it and relate it with aroute pattern
See below link for config
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmcfg/b03trpat.pdf
regards
Ronak patel
thank you Ronfak , but there is no any change
HI
Have you assigned it to ip phone's DP or IP phone directly. this CSS has to hit on the phone on which you want to remove the STD code.
Ronak patel
