Is there a way to bulk delete messages . User has around 100 messages, how can I delete them all at once.Thanks
Hello, I have a 7962G that doesn't want to boot. It powers on, then just sits there with nothing on the screen. I have many other phones working. I did the factory reset and then tried a hard reset. Later I did the boot with the handset off a...
Hi all,we have recently terminated sip trunk on one of our customers site there seems to be problem with Unity as AA and voicemail is not functioning properly.The AA has number 2293100, extensions are 4 digits in range of 2293100-229399. I have to ...
Hi ,We integrate the CUCM , UCCE ,GW with CUOM 8.6. We faced the below issue for all the monitored device.PerformancePollingStopped . when we checkd the event details got a message as Cannot collect data .The device has no credential Information.All ...
Hi, I have a small doubt.The Switch ports which we having in UC 500 is either L2 or L3..Why i am asking is this one of our client is intrested to move on Cisco UC 500 and they are having central site 40 users and in remote only 4users.Already they...
HelloI will be integrating Unit connectoin with LDAP, after intefgration with LDAP what will be the impact on existing users voice mails & passwordsAny othe issues I need to be aware of ?I already have integrated LDAP with cucm, what will be the impa...
Hi Everyone, 1)Can you please tell me what are the maximum number of Personal Address Book entries can be added in Cisco 7942, Cisco 7965 phones
I had configured the night service as below but the call is not forward during night-service hours, please let me know what we are missing on this below configuration.Telephone-service night-service day Sun 17:00 07:59 night-service day Mon 17:00 07:...
Hi.If anyone could help on this one it would be great.Our incoming calls from the PSTN keeps failling. Incoming/outgoing calls across the WAN does work, and outgoing calls across the PSTN also works fine.We use MGCP gateways. A show isdn stat shows l...
Hi,I am having an E1 connection with 3 series of telephone numbers (100 numbers in each series). I am having an analog FAX machine (RJ11 connection). I need to configure one number from the E1 to this fax.The E1 is terminated on a 2911 router which i...
I have a problem with the incoming calls from the same city or province .the incoming number has an area code although that call is coming form the same city .could you please tell me how can i solve this issue to remove the area code
Hi ,I have a Disk problem with my CUCM :The result of "show status" command is : Total Free UsedDisk/active 12316656K 12728K 12178796K (100%)Disk/inactive 12316672K 11658176K...
how to identify an incoming phone number in the ivr (CRS)?
HIi have a cisco cme 7.1all configuration regarding time, ntp server(which is the same cme), time-zone, clock set..ect have been configured as below:clocktimezoneYemenT 3ntp master 1ntp server 10.0.2.254 (cme ip address)!telephony-servicetime-zone 31...
Hi Guys,Hope I can seek a little help here. When I tried to configured the time-zone for country Tonga in the CME Telephony-service, I can't seem to have the selection of GMT+13 (equivalent to offset +780 min), the most is +12. Other than adjusting t...
Subject | Author | Posted |
05-12-2025 12:06 PM | ||
05-12-2025 06:55 AM | ||
05-11-2025 04:59 AM | ||
05-05-2025 11:16 AM | ||
04-30-2025 05:24 AM |
User | Count |
5 | |
3 | |
1 | |
1 | |
1 |
