03-21-2011 07:32 AM - edited 03-16-2019 04:03 AM
While installing cucm in vmware workstation 7.0 ..the ntp server ip is asking ...how to set ntp ???/??
03-21-2011 07:34 AM
If your firewall policy allows ntp access to the internet,
you can use something like pool.ntp.org. If you do not have access to a valid ntp source, the installation will fail.
03-21-2011 07:37 AM
i dont have network access ..so is ter any other options
03-21-2011 07:51 AM
You will have to come up with an ntp source or you will not be able to install. You can configure ntp service on Windows or Linux servers with little trouble.
03-21-2011 08:37 AM
thanks for your reply ..can u suggest me a method to install ntp in my windows seven
03-21-2011 08:53 AM
Sorry, never tried it. Might have to try for some help in Microsoft support groups.
