03-04-2010 02:51 PM - edited 03-15-2019 09:39 PM
Hello Everyone,
I've moved from running CUCM 6.01 to an MCS platform, it is actually an IBM x346 which recognizes as an MCS 7845-I. Apparently I can not install Unified Communications Manager Business Edition on this particular MCS model. So now I am going to have to install CallManager on the MCS and install Unity Connections on a separate server. My question is how? I assume I install the CallManager first, but then what steps do I have to take to install Unity Connections on another server and then register it to the CallManager server and integrate them so I can use Unity Connections for voicemail? Any help on this is greatly appreciated. Thanks in advance!
Solved! Go to Solution.
03-04-2010 02:59 PM
Refer to the appropriate guide:
http://www.cisco.com/en/US/products/ps6509/products_installation_and_configuration_guides_list.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
03-04-2010 02:59 PM
java
