integrated cisco ip phone 7821 on router 2851Vsec
Hello
I have actual router cisco 2851 Vsec with ip phone 7911, and your data as eol 7911 and eos, I opted to the 7821 purchase, it ties my not compatible with the 2851 CME router
thank you help me find a solution to the integrated IP phone on the 7821 router 2851vsec
attached file cisco router configue 2851vsec
thank you to answer me is really urgent
Best regards
Ryad
Javaid Lillah
Hello Abderrahmani,
Cisco handset 7821 doesn't support SCCP protocol hence will not work in normal CME like 7911 however this can be configured in SIP mode. First of all you will need to get the phone loads from cisco website sip78xx.10-2-1-12SR1-4.loads (any latest loads can work also) and then place these loads file on the router's flash. Once this is done apply the below configuration (change parameters based on your requirement).
voice register global
mode cme
source-address 192.168.25.1 port 5060
max-dn 100
max-pool 50
load 7821 sip78xx.10-2-1-12SR1-4
authenticate register
authenticate realm all
tftp-path flash:
create profile
voice register dn 1
number 1111
allow watch
name Javaid Lillah
label 1111
voice register pool 1
busy-trigger-per-button 1
id mac FFFF.FFFF.FFFF
type 7821
number 1 dn 1
presence call-list
dtmf-relay sip-notify
username 1111 password FFFF
codec g711ulaw
Please rate if this is helpful.
