12-21-2015 08:43 AM - edited 03-17-2019 05:18 AM
IP phone 7861 (sip78xx.11-0-1-11) registers on CUCM 8.6.2 and after some time unregisters. Then registers again and so on.
Logs say someting like that
2651 NOT Dec 21 18:20:10.981122 JAVA-Thread-6|JPlatUi:setUnregReason - old-unregister-reason:107, new unregister-reason:24, cc-server-type:0 2652 NOT Dec 21 18:20:10.981672 JAVA-Thread-6|JPlatUi:isThisFailureFromNewCause - old unregReason =107 newUnregReason=24 2653 NOT Dec 21 18:20:10.990600 JAVA-Thread-6|JPlatUi:setUnregReason - set to unregister-reason:24 2654 NOT Dec 21 18:20:11.111551 dgetserver(3908)-dgetserver.RESULT [_0_ [PASS] No error ] 2655 NOT Dec 21 18:20:11.136692 downd-SOCKET accept errno=4 "Interrupted system call" 2656 NOT Dec 21 18:20:11.265518 JAVA-Thread-6|cip.sipcc.SipEnhancedAlarmInfo:setLastDeregistrationReason - new unreg-reason=24(LastTimePhoneRegRej), old unreg-reason=107
and that
Time zone data download failed
What can I do to solve this problem?
12-21-2015 09:34 AM
Hi Pavlo,
I would suggest a restart of the tftp service followed by phone reset. If the issue persists please provide a packet capture from the phone.
Manish
- Do rate helpful posts -
12-21-2015 09:46 AM
Hi Pavlo,
In addition to what Manish has said, you can also have a look into the link since error snapshot talks about Time zone data download failed
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118744-technote-cucm-00.html
In order to avoid known problems with DST update changes on phones and CUCM systems (from Version 8.X to Version10.5), remember these concerns:
regds,
aman
12-22-2015 07:58 AM
tftp restart and phone reset don't resolve problem. The problem is: Phone can't register with Publisher (first in CM group) and registers with Subscriber. Then phone detects that Publisher is online and try to register with it. But it fails and registers with Subscriber and so on.
What can I see in capture? I don't want to post it in Internet. Can I send it to your e-mail?
12-22-2015 10:04 AM
Are there other phones registered with the Publisher server? If not , can you check if callmanager service is running on the publisher.
Manish
12-23-2015 02:27 AM
There are registered a lot of devices with both Publisher and Subscriber: 79XX phones, CIPC, Cisco jabber, 3rd party SIP phones, etc.
There are device packs on both servers with latest firmware for 7861.
12-23-2015 02:58 AM
You can check in the captures if the phone is sending a register request to Pub and if Pub is responding with a 200 ok. If not then this should be investigated on cucm side, you may contact TAC if you do not want to share traces over support community.
Manish
12-23-2015 03:06 AM
Did u ever restart your CUCM servers after adding Device pack?
regds,
aman
12-22-2015 06:51 PM
Hi Pavlo,
Did u upload any device pack on both CUCM servers and rebooted the servers as well?
just refer this link
http://voiceonbits.com/2014/06/17/scenario45-7841-sip-phone-in-registration-loop/
regds,
aman
