Integration with asterisk solution
chingkiatlee
I plan to setup a normal integration with Asterisk (Free VoIP Solution) with Cisco Router 3725. The connection as below
CUCM -> (UTP) -> Cisco 3725 -> (E1 back to back cable) -> Asterisk Server -> (PRI) -> Asterisk Server outside
I do able to established the D-Channel connection with Asterisk Server locally. But when i do a call, the RTP failed to stream out.
The calling number can be display on the called user & vice-versa. But not the RTP package.
But what i found out is the Asterisk Server is only accepted G711.alaw codec (correct me if i am wrong) but my CUCM calling out is using G711.ulaw codec. So it there cause the problem?
CUCM version is 7.1 but the 3725 IOS SCCP only supported up to CUCM 3.4, so i failed to use the trancording.
So is anyone have the solution?
acampbell
Can you post the show run from your 3725 router.
Alex
Regards, Alex. Please rate useful posts.
9 Replies 9
acampbell
Alex
VoiceGW#sh run
Building configuration...
Current configuration : 2628 bytes
! Last configuration change at 12:45:51 MY Tue Nov 2 2010
! NVRAM config last updated at 12:45:55 MY Tue Nov 2 2010
version 12.3
hostname HOST
boot-start-marker
boot-end-marker
enable secret 5 $1$okKg$J7Q0EIq8i1Jq3BmNsR5K1/
clock timezone MY 8
no network-clock-participate slot 1
network-clock-participate wic 0
network-clock-select 1 e1 0/0
voice-card 1
dspfarm
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 172.17.0.1 172.17.0.20
ip dhcp excluded-address 172.71.0.1 172.71.0.20
ip dhcp pool Voice
   network 172.17.0.0 255.255.248.0
   default-router 172.17.0.1
   option 150 ip 172.17.0.5
ip dhcp pool voice-new
   network 172.71.0.0 255.255.254.0
   default-router 172.71.0.1
   option 150 ip 172.71.0.4 172.71.0.5
no ftp-server write-enable
isdn switch-type primary-net5
voice service pots
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
controller E1 1/0
pri-group timeslots 1-31
description Connection to PSTN(MAXIS) 2888 E1 #1
controller E1 1/1
description Connection to PSTN(MAXIS) 2828 E1 #2
interface FastEthernet0/0
ip address 172.17.0.8 255.255.248.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn timer T310 120000
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
no cdp enable
interface Serial1/0:15
no ip address
no cdp enable
interface Serial1/1:15
no ip address
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 172.17.0.1
ip http server
voice-port 0/0:15
echo-cancel coverage 32
timeouts interdigit 2
voice-port 1/0:15
cptone MY
timeouts initial 0
voice-port 1/1:15
cptone MY
timeouts initial 0
dial-peer voice 1000 pots
preference 10
destination-pattern 9T
progress_ind alert enable 8
direct-inward-dial
port 1/0:15
dial-peer voice 1001 pots
preference 1
direct-inward-dial
port 1/1:15
dial-peer voice 2000 voip
preference 10
destination-pattern .T
progress_ind setup enable 3
voice-class codec 1
session target ipv4:172.17.0.6
dtmf-relay h245-alphanumeric
dial-peer voice 2001 voip
preference 1
voice-class codec 1
session target ipv4:172.17.0.5
dial-peer voice 3000 pots
preference 6
destination-pattern 0T
direct-inward-dial
port 0/0:15
line con 0
line aux 0
line vty 0 4
password cisco123
login
ntp clock-period 17180644
ntp master
ntp server 172.16.10.21
end
Hi acampbell,
FYI.
The D-channel is working fine & the signalling do pass thru, only the RTP does not work.
Not audio for both side.
ashok_boin
Level 5
Level 5
Asterisk do support other codecs.
http://www.voip-info.org/wiki/view/Asterisk+codecs
Regards...
-Ashok.
With best regards...
Ashok
Hi ashok,
Do this supported for Qsig connection?
Cause based on the engineer, he do said it only supported for SIP trunk.
Correct me if i am wrong.
Hi Lee,
Yes, Asterisk does support QSIG a long back.
Pls see the article in 2005 published in network world magazine.
http://www.networkworld.com/news/2005/111605-asterisk-voip.html
Can you please post any debugs from 3725 to Asterisk (signaling + media)? And also, what's the relevant config in the above shared config for Asterisk server including interface?
Regards...
-Ashok.
Ashok
Mar 22 03:24:51.996: //-1/801AAC6A2C00/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=2027
   ----- ccCallInfo IE subfields -----
   cisco-ani=2027
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1234
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1
Mar 22 03:24:51.996: //-1/801AAC6A2C00/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x6509D0E4, Call Info(
   Calling Number=2027(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1234(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subsriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=2002, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=7
Mar 22 03:24:51.996: //-1/801AAC6A2C00/CCAPI/ccCheckClipClir:
   In: Calling Number=2027(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=2027(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Mar 22 03:24:51.996: //7/801AAC6A2C00/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=2027(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1234(TON=Unknown, NPI=Unknown))
Mar 22 03:24:52.000: //7/801AAC6A2C00/CCAPI/cc_process_call_setup_ind:
   Event=0x6530F668
Mar 22 03:24:52.000: //7/801AAC6A2C00/CCAPI/ccCallSetContext:
   Context=0x658BDE60
   >>>>CCAPI handed cid 7 with tag 2002 to app "_ManagedAppProcess_Default"
Mar 22 03:24:52.000: //7/801AAC6A2C00/CCAPI/ccCallProceeding:
Mar 22 03:24:52.000: //7/801AAC6A2C00/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=3000, Params=0x658BEAF0, Progress Indication=NULL(0)
Mar 22 03:24:52.000: //7/801AAC6A2C00/CCAPI/ccCheckClipClir:
   Destination Pattern=1234, Called Number=1234, Digit Strip=TRUE
   Redirect Number=, Display Info=
   Account Number=2027, Final Destination Flag=TRUE,
   Guid=801AAC6A-92E2-D1E9-2C00-B903AC1901BC, Outgoing Dial-peer=3000
Mar 22 03:24:52.000: //7/801AAC6A2C00/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=2027
   cisco-ani=2027
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1234
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Mar 22 03:24:52.004: //7/801AAC6A2C00/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x6534EB18, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=2027(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1234(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subsriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3000, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Mar 22 03:24:52.004: //8/801AAC6A2C00/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Mar 22 03:24:52.004: //8/801AAC6A2C00/CCAPI/ccCallSetContext:
   Context=0x658BEAA0
Mar 22 03:24:52.004: //7/801AAC6A2C00/CCAPI/ccSaveDialpeerTag:
Mar 22 03:24:52.004: ISDN Se0/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 2027
Mar 22 03:24:52.008: ISDN Se0/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Called num 1234
Mar 22 03:24:52.008: ISDN Se0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0083
        Sending Complete
This is not helping much.
Can you pls try with "debug voip ccapi inout" and share the output? If needed, you can perform "debug vtsp rtp" command to debug RTP packet debugging later.
Regards...
-Ashok.
Ashok
Hi Ashok,
This is the debug voip ccapi inout result right?
below is the debug isdn q931 result.
Mar 22 03:32:49.601: ISDN Se1/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 2027
Mar 22 03:32:49.601: ISDN Se1/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num <>
Mar 22 03:32:49.601: ISDN Se1/1:15 Q931: TX -> SETUP pd = 8  callref = 0x008A
        Bearer Capability i = 0x8890
                Standard = CCITT
                Transfer Capability = Unrestricted Digital
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9838F
                Exclusive, Channel 15
        Calling Party Number i = 0x0081, '2027'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '<>'
Mar 22 03:32:49.637: ISDN Se1/1:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x808A
Mar 22 03:32:49.813: ISDN Se1/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x808A
Mar 22 03:32:50.865: ISDN Se1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x808A
        Cause i = 0x8090 - Normal call clearing
Mar 22 03:32:50.869: ISDN Se1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x008A
Mar 22 03:32:50.897: ISDN Se1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x808A
