Integration With YX Wireless Sip Device Fail
Hi All,
We have purchase a device for mobile calls and it works with SIP protocol, our configuration is:
* CUCM 8.5
* Voice Gateway 3825 with IOS: c3825-adventerprisek9-mz.124-24.T6.bin
* Cisco Ip Phones registered in Callmanager with SCCP
* Eyebeam softphone registered in CallManager as a SIP Device.
On CUCM i have been configured only the route pattern.
The SIP connection to the device is in the gateway (See dial-peer 5000), this is the configuration of the gateway:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol cisco
h323
  call start slow
sip
  registrar server expires max 3600 min 3600
  no update-callerid
voice class codec 1
codec preference 1 g729br8
codec preference 2 g729r8
codec preference 3 g711ulaw
codec preference 4 g711alaw
voice translation-rule 200
rule 1 /^9030/ //
voice translation-profile celular
translate called 200
***Incoming dial-peer  from CUCM****
dial-peer voice 1000 voip
voice-class codec 1
incoming called-number 9030..........
*** Outgoing Dial-peer*****
dial-peer voice 5000 voip
description SALIDA Celular Celufijo DualSim
translation-profile outgoing celular
service session
destination-pattern 9030..........
voice-class codec 1
session protocol sipv2
session target ipv4:10.130.1.9
dtmf-relay sip-notify rtp-nte
Every time when try to call from IpCommunicator or another SCCP phone  the call is dropped  but when i call from Eyebeam softphone it works correctly.
Note: 10.130.1.4 --> Ip Address of CUCM
         10.130.1.2 --> Ip Address of Voice Gateway.
         10.130.1.9 --> Ip Address of YX Wireless Sip Device (thirt party device)
Attach you can find:
debug ccsip calls ( For both IpPhone SCCP and Eyebeam Sip Softphone)
debug voice ccapi inout ( For both  IpPhone SCCP and Eyebeam Sip Softphone)
Any help will be appreciate.
Thanksss.
Any can help with this..
Thanksss
Did you solve the problem?
Because I´m trying to configure an YX Wireless Lyric VoIP as a SIP Trunk for a UC540, but I can´t, any advice would be helpful.
Thanks.
Hi Christian,
Did you solve the problem with the integration? We would like to buy the same Lyric equipment, however the Lyric's documentation does not specify integration with Cisco.
Thank you.
Hi Friend...
Not, we finally purchase another equipment from another provider (Easy Phone Goip)
Good luck
