03-05-2007 09:25 AM - edited 03-14-2019 08:19 PM
I set an Inter-Cluster Trunk between my CCM and a PBX.
If MTP required is not checked, I haven't audio problem but I can't hold, transfer...
If MTP required is checked, I have audio problem (a "local" echo on H323 phone registered to pbx) and no problem with hold, transfer...
Does somebody know how to solve my issue?
Best regards.
03-09-2007 11:20 AM
It look like problem related with Gateway , upgraded the gateway to 12.4.6T. MTP is being used on callmanager to provide
supplementary service.
03-09-2007 05:15 PM
Echo results from the audio signal being reflected back to the talker with delay. In your case that reflection is coming from the MTP, so you need to focus there. What flavor of MTP are you using? Is it software or hardware? Can you try a different MTP resource? If hardware DSP farm are there errors?
Please rate helpful posts.
Dave
