Inter Digit Command Not Working 2951
cneves7007
Hello, while my router is in E-SRST mode, any calls made out of any of the voice ports has a 10 sec delay before any ringing occurs. I aware of the inter digit timeout as the default. When I change the inter digit timeout to 2 secs, I still get the 10 sec delay? Any solution to this?
IOS:c2951-universalk9-mz.SPA.155-2.T1.bin
Thank you,
Chad
You are disabling KPML dialing on your SIP phones. This means that your phone is trying to match a route pattern before sending the call to the SRST gateway. This is called enbloc dialing where SIP phones start taking call routing decisions based on SIP dial rules. In KPML, SIP phone will act as SCCP phone to send digit-by-digit to the gateway.
Apply this command to all voice register pools and test.
voice register pool  X
 digit collect kpml
7 Replies 7
Terry Cheema
Check your dial-peers, for any overlapping dial plan.
-Terry
Please rate all helpful posts
Please share the config
Hello, here is the current config:
show run
Building configuration...
Current configuration : 15410 bytes
! Last configuration change at 08:43:45 PDT Thu Jul 30 2015 by amsnet
! NVRAM config last updated at 08:43:46 PDT Thu Jul 30 2015 by amsnet
version 15.5
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname EKEMBL-2951
boot-start-marker
boot system flash flash0:c2951-universalk9-mz.SPA.155-2.T1.bin
boot system flash flash0:c2951-universalk9-mz.SPA.152-2.T.bin
boot-end-marker
logging buffered 32768
enable secret 5 $1$lFee$Dtdcjo3qvu7qSw/p3Kkxl1
no aaa new-model
ethernet lmi ce
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
clock timezone PST -8 0
clock summer-time PDT recurring
no ip domain lookup
ip domain name sac-city.k12.ca.us
ip multicast-routing
ip cef
no ipv6 cef
trunk group Analog
 description Analog Trunk Group
 hunt-scheme sequential both down
cts logging verbose
crypto pki trustpoint TP-self-signed-117389201
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-117389201
 revocation-check none
 rsakeypair TP-self-signed-117389201
crypto pki certificate chain TP-self-signed-117389201
 certificate self-signed 01
  30820254 308201BD A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31313733 38393230 31301E17 0D313230 32313030 30303933
  365A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3131 37333839
  32303130 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  E9CDE6B1 B055EF15 C8ACF1ED C448A4DB 31E459BA 0B85F1AA EC2C5B86 CEC957C0
  BD21B1D1 B9238CEC 7935A873 1C4442D8 C7B97D76 EA2716B6 C6CE5A67 2F773260
  D9003965 330B93B8 FDA1FE87 44CB3ED2 569B9F17 B7A9EA9D 509B65BA 7EADF499
  BAF0CC34 4F653B6B 2688F4AC 2A49807F AEFEFFC5 0DBB1C73 A011F5F4 F0FD9F4F
  02030100 01A37E30 7C300F06 03551D13 0101FF04 05300301 01FF3029 0603551D
  11042230 20821E45 4B454D42 4C2D3239 35312E73 61632D63 6974792E 6B31322E
  63612E75 73301F06 03551D23 04183016 80149750 B2715610 1D591859 CBC3BE0A
  55D03221 5017301D 0603551D 0E041604 149750B2 7156101D 591859CB C3BE0A55
  D0322150 17300D06 092A8648 86F70D01 01040500 03818100 9A188C25 188370F2
  78C0473C FE3284FB 4A8A0485 99967A4A F8026F9C 34722CB2 314BB385 758CC308
  E452369B E0D74A4D E8A3F639 0CC53876 E6FA08D2 16FB4258 0FCD3204 705AC711
  95A6600D 3769F46D 1B71C432 6373D470 269D19CF 6ECAD58F 1167E257 CC53301F
  59FAD61E DF7A9BD0 00BE156B AA45D027 8767CEFE 5E2172FE
  quit
voice-card 0
 dspfarm
 dsp services dspfarm
voice service voip
 ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  registrar server expires max 600 min 60
  redirect contact order best-match
voice register global
 mode esrst
 system message CM Fallback Service Operating
 max-dn 100
 max-pool 200
voice register dn  1
 number 211000
 shared-line
voice register pool  1
 id network 10.67.200.0 mask 255.255.255.0
 no digit collect kpml
voice register pool  2
 id network 10.67.201.0 mask 255.255.255.0
voice register pool  3
 id network 10.67.202.0 mask 255.255.255.0
voice register pool  4
 id network 10.67.203.0 mask 255.255.255.0
voice register pool  5
 id network 10.67.204.0 mask 255.255.255.0
voice register pool  6
 id network 10.67.205.0 mask 255.255.255.0
voice register pool  7
 id network 10.67.206.0 mask 255.255.255.0
voice register pool  8
 id network 10.67.207.0 mask 255.255.255.0
application
 global
  service alternate Default
license udi pid CISCO2951/K9 sn FTX1603AH12
hw-module pvdm 0/0
username admin privilege 15 secret 5 $1$V4t7$cDclqEj3mssum1mAAtjKx1
username amsnet privilege 15 secret 5 $1$u.f4$Q2XOklWc3UCICOAMyt4YM/
username tech privilege 7 password 7 1079013911011B581B
username prime privilege 15 secret 5 $1$ax2f$uqIfymLghEsr9vtAzpkwh.
redundancy
class-map match-all VVLAN-ANY
 match access-group name VVLAN-ANY
class-map match-any Network_Control
 match ip dscp cs6
class-map match-all Default
 match ip dscp default
class-map match-all Voice_Control
 match ip dscp cs3
class-map match-all Video
 match ip dscp af41
 match ip dscp ef
class-map match-all Scavenger
 match ip dscp cs1
class-map match-all District-VOICE
 match access-group name District-VOICE
class-map match-all District-CALL-SIGNALING
 match access-group name District-CALL-SIGNALING
policy-map QOS_Out
 class Voice
  priority
 class Voice_Control
  police 600000 1500 conform-action transmit  exceed-action set-dscp-transmit cs1
 class Video
  police 2000000 1500 conform-action transmit  exceed-action set-dscp-transmit cs1
 class Network_Control
  police 200000 1500 conform-action transmit  exceed-action set-dscp-transmit cs1
 class Scavenger
  police 600000 1500 conform-action transmit  exceed-action set-dscp-transmit default
 class class-default
policy-map QOS_In
 class District-VOICE
  set dscp ef
 class District-CALL-SIGNALING
  set dscp cs3
 class VVLAN-ANY
  set dscp cs1
 class class-default
  set dscp default
policy-map Parent_Policy
 class class-default
  shape average 100000000
   service-policy QOS_Out
interface Loopback1
 ip address 10.67.255.1 255.255.255.255
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description Circuit 15L2XN000126-001PT
 no ip address
 duplex full
 speed 100
interface GigabitEthernet0/0.1
 encapsulation dot1Q 1 native
interface GigabitEthernet0/0.41
 description Wan_Uplink
 encapsulation dot1Q 41
 ip address 172.17.0.134 255.255.255.252
 ip access-group SRST in
 ip pim sparse-mode
 ip ospf network point-to-point
 service-policy output Parent_Policy
interface GigabitEthernet0/1
 description Kemble_Core_Uplink
 ip address 10.67.254.1 255.255.255.252
 ip pim sparse-mode
 duplex auto
 speed auto
 service-policy input QOS_In
interface GigabitEthernet0/2
 description Chavez_Core_Uplink
 ip address 10.68.254.1 255.255.255.252
 no ip redirects
 ip pim sparse-mode
 duplex auto
 speed auto
router ospf 1
 area 67 stub no-summary
 area 67 range 10.67.0.0 255.255.0.0
 area 68 stub no-summary
 network 10.67.254.0 0.0.0.3 area 67
 network 10.68.254.0 0.0.0.3 area 68
 network 172.17.0.132 0.0.0.3 area 0
 network 0.0.0.0 255.255.255.255 area 67
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip pim rp-address 10.7.255.1
ip access-list standard SRST
 deny   10.7.200.11
 deny   10.7.200.10
 permit any
ip access-list extended District-CALL-SIGNALING
 permit tcp 10.67.192.0 0.0.31.255 any range 2000 2002
ip access-list extended District-VOICE
 permit udp 10.67.192.0 0.0.31.255 any range 16384 32767
ip access-list extended VVLAN-ANY
 permit ip 10.67.192.0 0.0.31.255 any
logging host 10.7.98.9
logging host 10.7.98.249
nls resp-timeout 1
cpd cr-id 1
snmp-server community $monitor RO
snmp-server community Whattraps RW
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps ds1
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps gatekeeper
snmp-server enable traps xgcp
snmp-server enable traps license
snmp-server enable traps envmon
snmp-server enable traps flash insertion
snmp-server enable traps flash removal
snmp-server enable traps c3g
snmp-server enable traps ds3
snmp-server enable traps adslline
snmp-server enable traps vdsl2line
snmp-server enable traps icsudsu
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps energywise
snmp-server enable traps mac-notification
snmp-server enable traps bgp
snmp-server enable traps isis
snmp-server enable traps aaa_server
snmp-server enable traps atm subif
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps memory bufferpeak
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps resource-policy
snmp-server enable traps event-manager
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps nhrp nhs
snmp-server enable traps nhrp nhc
snmp-server enable traps nhrp nhp
snmp-server enable traps nhrp quota-exceeded
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps vtp
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps ipsla
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps rf
snmp-server enable traps ccme
snmp-server enable traps srst
snmp-server enable traps voice
snmp-server enable traps dnis
snmp-server host 10.7.98.249 $monitor
snmp-server host 10.7.98.249 Wh@ttr@ps
snmp-server host 10.7.98.9 Whattraps
control-plane
voice-port 0/0/0
 trunk-group Analog 1
 timing hookflash-out 50
 timing guard-out 1000
 connection plar 211000
 description Backup Analog 916-433-5026
 caller-id enable
voice-port 0/0/1
 trunk-group Analog 2
 description Backup Analog 916-433-5027
 caller-id enable
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
 description Paging Integration
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
 description Intercom Modem 916-395-3928
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
mgcp
mgcp call-agent 10.7.200.11 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp bind control source-interface GigabitEthernet0/1
mgcp bind media source-interface GigabitEthernet0/1
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
ccm-manager music-on-hold
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.7.200.10
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager config server 10.7.200.10
ccm-manager config
dial-peer voice 99900990 pots
 service mgcpapp
 port 0/0/0
dial-peer voice 99900991 pots
 service mgcpapp
 port 0/0/1
dial-peer voice 99900992 pots
 service mgcpapp
 port 0/0/2
dial-peer voice 99900993 pots
 service mgcpapp
 port 0/0/3
dial-peer voice 99901990 pots
 service mgcpapp
 port 0/1/0
dial-peer voice 99902990 pots
 service mgcpapp
 port 0/2/0
dial-peer voice 999000 pots
 service mgcpapp
 port 0/0/0
dial-peer voice 999001 pots
 service mgcpapp
 port 0/0/1
dial-peer voice 999002 pots
 service mgcpapp
 port 0/0/2
dial-peer voice 999003 pots
 service mgcpapp
 port 0/0/3
dial-peer voice 999010 pots
 service mgcpapp
 port 0/1/0
dial-peer voice 999020 pots
 service mgcpapp
 port 0/2/0
dial-peer voice 99900099 pots
 service mgcpapp
 port 0/0/0
dial-peer voice 99900199 pots
 service mgcpapp
 port 0/0/1
dial-peer voice 99900299 pots
 service mgcpapp
 port 0/0/2
dial-peer voice 99900399 pots
 service mgcpapp
 port 0/0/3
dial-peer voice 99901099 pots
 service mgcpapp
 port 0/1/0
dial-peer voice 99902099 pots
 service mgcpapp
 port 0/2/0
dial-peer voice 911 pots
 trunkgroup Analog
 destination-pattern 911
 forward-digits all
 prefix 8
dial-peer voice 8911 pots
 trunkgroup Analog
 destination-pattern 8911
 forward-digits 4
dial-peer voice 7 pots
 trunkgroup Analog
 destination-pattern 8[2-9]......
 forward-digits 9
dial-peer voice 999999 pots
 destination-pattern #
 port 0/1/0
 forward-digits 0
 prefix #00*
dial-peer voice 11 pots
 trunkgroup Analog
 destination-pattern 81[2-9].........
 forward-digits 12
sip-ua
 refer-ood enable
gatekeeper
 shutdown
call-manager-fallback
 max-conferences 4 gain -6
 transfer-system full-consult
 timeouts interdigit 2
 ip source-address 10.67.254.1 port 2000
 max-ephones 150
 default-destination 211000
banner login ^CC
WARNING! Unauthorized use of this system is prohibited.
You will be prosecuted to the full extent of the law.
-----------------------------------------------------------------------^C
banner motd ^CC
line con 0
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 privilege level 15
 login local
 transport input telnet ssh
line vty 5 15
 privilege level 15
 login local
scheduler allocate 20000 1000
ntp server 172.17.0.133
end
EKEMBL-2951#
 digit collect kpml
Hello Mohammed,
thank you for your response. I made the changes as you requested but get the same result?
Thank you,
Chad
Mohammed,
Thank you for your recommendations they worked. I just needed to re-register the phones to call manager. After that it worked.
Thank you,
Chad
cneves7007
Not sure if I replied but you recommendation worked.
Thank you!
