08-13-2009 07:00 AM - edited 03-15-2019 07:21 PM
Could anyone please tell me the firewall access port to be open for non gatekeeper controlled intertercluster trunk for communication manager 7.0
08-13-2009 07:10 AM
Refer to this doc
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/port/7_1_2/CCM_7.1.2PortList.pdf
java
if this helps, please rate
08-13-2009 07:51 AM
I already referred that and I'm not able to see any port for two different call manager clusters over the WAN.
08-13-2009 08:40 AM
The port IS there, i already looked in the doc.
The port is no different whether you're using it across the WAN/LAN/MAN, etc
Search ICT
The doc contains ALL the ports that CUCM uses for communication between all the different servers and devices.
java
